Door handle lubricate?
My driver side door handle on the inside is squeaking (06 2LT). The squeak sounds like it is coming right from the handle itself. Anyone know if there is there a way to lube it?
silicone spray pick up at any auto parts store
Sounds good- thanks.
could also mean that your door handle spring is about to snap..feel loose at all or a little play to it? hopefuly not and the grease fixes it :)
silicone spray has numerous uses also. I wipe my door seals with it. squirt the door hinges. & etc, etc..
Good stuff !!:twothumbs: |
