Driver side window 2011 HHR
I inastalled anoher window switch. Still the drivers window will not move. As I have said before I also installed a new motor. I can get he motor to move by appling voltaage directly to the plug. I have no voltage coming out of the switch! I do have voltage on the small wires going to the switch. (Small yellow & Green?)
Again I say I hear something that sounds like a relay when I move the switch in the down and up mode. And the fuses are good Item 17 is the one next to the radio and the fuse under the hood! I am at the end of the road on things to check Is there a fuse behind the RAP ? I will try to send a photo of the back side of the switch to show thew small wires! |
I posted in your other thread.
