Drivers window
Has anyone removed the drivers window? Is it difficult?
Found this using Google "removing front door window hhr" , That also turned up a few links to this forum, leading me to believe the search tool would be helpful.
It is fairly easy, be careful and don't over tighten the fasteners
It looks like once you remove the regulator, you should be able to let the window down some and rotate the front down further until it is nearly vertical and pull it out the top?
Looks like it.
