Erratic outside temperature indication
I am getting erratic readings on my outside temperature indication. Any idea why?
I guess I'll ask the obvious questions; What has changed since the last time it worked properly, anything? What year, model, trim.
:welcome8: to the forum refowler!
Can you elaborate a bit more on "erratic"? |
Originally Posted by refowler
(Post 621463)
Erratic Outside Temp Indication
Originally Posted by donbrew
(Post 621469)
Temp indicator is slow to respond. It will stick on one indication and not change until the temp has significantly changed. Where is it located? Can you clean it? |
(Post 621882)
2008 SL
I believe the magic number is 18 minutes of driving for the outside temperature display a revised reading if it has become "frozen" at the last reading. All three of mine tell me how cold it was in the garage overnight for about 1/4 of my drive to the office, then they wake up and sync with the true outside temperature.
I concur with 843de. There is a delay in the ambient temperature update when it is obviously warmer when first starting the engine than what it was when it was last turned off. I am not certain, but if it is colder when you start the engine than what it was when you last turned it off, then the ambient temperature will read correctly at start-up.
It must have something to do with the emission control algorithm in the computer. |
Originally Posted by kornellred
(Post 621982)
My 99 Buick had the same issues. The fix was to replace the temp sensor on the car. Easy fix, a PITA to locate where the sensor was located.
