front rotor and BRAKE pad bolts
what is the tool I need to remove the caliber bolts, and the rotor brace on a 2006 front breaks
14mm and 15mm sockets and a ratchet... here is a how to on front brakes:
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-replace-rotors-pads-06-hhr-15226/ |
However, my car uses calipers on the brakes.
I don't know what caliber rifle you would use to break an HHR.:corny: Okay, so I graduated from High School when you still had write papers by hand. Check your PM. |
I finally noticed this thread was in the "how to" forum. I moved it and corrected the spelling in the title.
