Keep in mind the "average MPG" includes idling (0 MPG).
So, .038 is within spec. Plugs should last at least 100,000 miles, that is the recommended time to change them. The maintenance schedule, and gapping is in your Owner Manual (link in my sig). |
Since putting these in, I've already put in 12 driving cycles, about 70 miles, with no missfires. I'll be doing a bit of running around today on various errands, and will finish off with a 60 mile trip on the Interstate. Should end up being around 125 to 140 miles total today.
Did you ask the dealer to replace the spark packs? They usually last forever, not a maintenance item. Look in your Owner Manual for the maintenance schedule; 100,000 miles is plugs and filters and looking at the exhaust and fuel system and trans fluid (if used in severe service).
Originally Posted by donbrew
(Post 959885)
Not this century. Most "misfires" are not really misfires they are caused by a loose timing chain.
Zero misfires in the last 427 miles since changing plugs & coil packs. I was getting infrequent misfires almost every drive before that, according to my old Craftsman OBD2 reader. I think that's a good indication it was plugs and/or coil packs...
(Post 959900)
A member here a few years back didn’t check his timing chain, threw parts at his P0300 and P0303 codes!
the front guide was damaged and he blew his engine when the timing chain jumped and the valves damaged the pistons. |
Been on this site since 2009, your info is wrong or generic or old. You need to understand what the computer sees as a P0300 "misfire": a variation in the speed of the crankshaft, NOT an actual misfiring of a spark plug. P030x is a different thing: the computer figures out which cylinder is misbehaving by telling what cylinder is supposed to be firing when the variation occurs.
Before OBD2 you could tell a misfire by listening to the engine, because there was an real misfire of a spark plug. For some reason P0300 gets the name "random misfire" or somesuch. What it actually is :"misfire detected" and misfire does not mean what an old time mechanic (before VVT) thinks. |
(Post 959908)
Before OBD2 you could tell a misfire by listening to the engine, because there was an real misfire of a spark plug. For some reason P0300 gets the name "random misfire" or somesuch. What it actually is :"misfire detected" and misfire does not mean what an old time mechanic (before VVT) thinks. I've not seen a P0300 in this car with either the Craftsman OBD2 reader, or the new scantool. I've already posted the P030x misfires recorded on each specific cylinder, though those were not the only P030x misfires recorded, just the ones from the last 10 trips, I've had P030x misfires recorded since I brought the LS home on Feb 17th but not P0300. AGAIN: Zero misfires recorded in the last 427 miles since changing plugs & coil packs. That's zero P0300's and zero P030x's. and BTW this whole tangent is not directly related to the thread... which is about the NGK Ruthenium HK plugs, and NGK U5180 coil packs. Even without misfires, I would have still changed them out just because of the mileage on them. Kind of like changing your oil before the DIC shows it's due, or having a new timing chain & related items installed before it's due. And on that original topic, I know it's highly suggestive, but it seems like the engine is running smoother after the swap. Also wrote down the mileage before fill up (mid point of trip), so I can track real MPG manually! |
Drive on! I’ve been a mechanic since 1973 , been working on HHR’s since 2007. One thing I ve learned is , it’s your car do what you want when you want to!
Google or Facebook don’t work on cars just opinions. I’ll take care of my HHRS as I have for a total of 843,000 miles. |
| All times are GMT -5. The time now is 09:34 AM. |
