Harmonic balancer question
Hi everyone, newbie here.
Had timing chain job recently done..now im faced w car dying every now and then...looked under the hood and noticed the the harmonic balancer dancing a bit; is this the cause of the stalling or perhaps a different sensor?.
thanks much in advance
P0106 Manifold Absolute Pressure (MAP) Sensor Performance
P0446 Evaporative Emissions (EVAP) Vent System Performance
P0451 Fuel Tank Pressure (FTP) Sensor Performance
P0455 Evaporative Emission (EVAP) System Large Leak
He was to have installed a new bolt for the harmonic balancer, and torque it properly, the crankshaft pulley bolt should be initially torqued to 74 ft-lbsfollowed by an additional 125 degrees.
