how to clean suede
does anyone know how to clean the suede on my seats. they have a little bit of dark color from my jeans.
you could try looking for something in the shoe department at a walmart or whatever, I think I have seen sprays for suade shoes.
if it's dye from your jeans, you probably wont be able to remove it.
I do not suggest using anything wet on it, or you will get a water spot the only thing I suggest you try is to get a white flexible eraser and try to lightly "erase the spot" others have had luck with this method. |
