how do you torque a 2007 2.2L automatic transmission?
Old Nov 7, 2015 | 09:13 PM
enjoyhhrs's Avatar
Question Transmission specs.
What are the Torque specs for a 2007 2.2L transmission pan,I'm referring to the 8 mm bolts
Old Nov 7, 2015 | 09:28 PM
Check post #14 - https://www.chevyhhr.net/forums/driv...n-39975/page2/
step 9: replace gasket & pan DO NOT over tighten the bolts. Use a 1/4 inch drive handle and just get them tight, (no King Kong fore arms), if you own an inch/lb torque wrench use it to spec 12 N.m or 106 lb. in. That is not much, just past "snug"!
Quoted from our DonBrew - the moderator with the dirty hands
Old Nov 7, 2015 | 09:58 PM
Whopper beat me to it! And tighten in an across the pan pattern, don't tighten one then the next to the left or right!
Old Nov 8, 2015 | 01:25 AM
Lucky's Avatar
Moved to general hhr from front page news.
Old Nov 8, 2015 | 09:58 PM
enjoyhhrs's Avatar
Exclamation how do you torque a 2007 2.2L automatic transmission?
suggestions how to torque these 8mm bolts
Old Nov 8, 2015 | 11:10 PM
Lucky's Avatar
With a torgue wrench?
I'm not sure I understand the question.
Old Nov 8, 2015 | 11:35 PM
Dbeluscak's Avatar
I usually give it the.... UGH! torque. Then go all the way around and pinch down each one a degree or two more. It's in inch pounds whatever the book says. I have 2 on the road now, no issues with either. And reused the factory gasket on both. The one that comes with the filter is a crappy rubber version of the real gasket.
I would just snug them up without breaking any, you should be fine. There is an Ecotec Performance Handbook available for Free online that has all your torque specs.
@ Lucky, how is it I never noticed you're from Seville!
Old Nov 9, 2015 | 12:47 AM
The proper torque specification is 10 Inch Pounds.
Old Nov 9, 2015 | 02:09 AM
He already asked the question in a different thread - and it was promptly answered. This thread is merged with his first.
enjoyhhrs - If you cannot find the items you previously posted: click on your registered name in the upperish right corner, and select "MY POSTS".
Old Nov 9, 2015 | 10:00 PM
Lucky's Avatar
@ Lucky, how is it I never noticed you're from Seville![/QUOTE]
Yep not far from Cleveland. I grew up in brookpark.
