motor mounts
Old 06-12-2018, 12:09 PM
Cliffs51's Avatar
motor mounts
Does someone know how far the back of the edge of the air cleaner top is from the edge of the cowling on an hhr with good motor mounts?
​​​​​​​Thanks
Cliffs51 is offline
Old 06-12-2018, 12:15 PM
aradmahogany's Avatar
No.... But if you look in your passenger wheel well there should be an access hole with the head of a bolt in the middle of it. If the head of the bolt is lower, then your upper mount is toast. Try a power brake test to check the mounts. You can also use a pry bar.
aradmahogany is offline
Old 06-12-2018, 12:20 PM
Cliffs51's Avatar
ok thanks ill check that. I know that they are hydraulic and over time they sag quite a bit. Ive read where a bad one can be what causes the flex pipe to crack
Cliffs51 is offline
Old 06-13-2018, 07:07 AM
And look for cracks in the transmission mounts.
Oldblue is online now
Old 06-13-2018, 07:26 AM
Cliffs51's Avatar
Definitely will. In looking on ebay I see lots of packs of 3 mounts but very few include the 4th mount which is the upper transmission mount. Is that because it rarely fails?
Cliffs51 is offline
Old 06-13-2018, 07:44 AM
I’m thinking. I haven’t had mine out yet to inspect it.
https://www.chevyhhr.net/forums/prob...problem-60373/
Timb727
186
05-18-2020 10:49 AM
BQS4
Maintenance and Upkeep
06-29-2014 02:35 PM
2011hhr2011
10-25-2011 02:00 AM
Miltown SS
10
04-13-2011 11:41 PM
SdgrS
2.0L Performance Tech
03-16-2009 12:02 PM
Quick Reply: motor mounts
