Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Is my timing chain hanging right? Pictures (https://www.chevyhhr.net/forums/maintenance-upkeep-50/my-timing-chain-hanging-right-pictures-67673/)
TurboKid1994 Aug 7, 2025 03:15 PM
Posted about this repair some time ago and just wanted to verify that my chain looks tight. Is there supposed to be any droop?
thx
https://cimg1.ibsrv.net/gimg/www.che...0e3ad0b0e.jpeg
https://cimg4.ibsrv.net/gimg/www.che...8e5256a45.jpeg
https://cimg5.ibsrv.net/gimg/www.che...615b43656.jpeg
RJ_RS_SS_350 Aug 7, 2025 03:20 PM
That's no good, it should be tight.
donbrew Aug 7, 2025 03:32 PM
Should be NO droop.
TurboKid1994 Aug 7, 2025 06:37 PM
Ouch!!! Maybe that’s the ticking noise I’ve been hearing. I don’t see any metal shavings so I guess that’s good. Why would it be this loose after everything replaced?
RJ_RS_SS_350 Aug 7, 2025 07:06 PM
Did you activate the tensioner? 9 months, I would expect catastrophic failure if it hadn't been activated, or hadn't activated itself automatically shortly after install. How many miles since the replacement?
TurboKid1994 Aug 7, 2025 07:09 PM
Around 7k miles at least… I’ll give er a good whopp and see if it tightens up… Gonna hate if I have to tear the front off again…
TurboKid1994 Aug 7, 2025 07:19 PM
Well, I gave it a good whack with a wooden dowel and the whitish colored plastic guide broke. Perfect.
RJ_RS_SS_350 Aug 7, 2025 09:34 PM
Well dam
TurboKid1994 Aug 14, 2025 08:33 PM
Well I got her done in a solid days work. The culprit was a bad tensioner! The chain was one tooth out of alignment as well. New front seal…
Anybody aware of how these tensioners go bad? I couldn’t really see any damage to any of its components. It felt a little sticky, but it was in the extended position. Very curious…
Runs so much smoother now, and no more noise! Love my little fella… thx
Oldblue Aug 15, 2025 06:59 AM
What brand chain kit did you first install?
