Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Never seen this before need help figuring out where to look (https://www.chevyhhr.net/forums/maintenance-upkeep-50/never-seen-before-need-help-figuring-out-where-look-67438/)
Bigge313 Feb 11, 2025 07:03 PM
https://cimg4.ibsrv.net/gimg/www.che...eda4235df8.jpg
what would I look.for that causes #2 to.look.like.this? Been getting misfire codes but engine is not runnig ruff at all. 07 with 188000 miles.
RJ_RS_SS_350 Feb 11, 2025 08:28 PM
:welcomewagon: to the forums!
What codes are you getting? P0300 and/or P0302? Or something else?
donbrew Feb 11, 2025 09:22 PM
What did the plugs look like?
firemangeorge Feb 11, 2025 09:54 PM
And what did the coil cap look like on cyl #2 ?
Bigge313 Feb 12, 2025 04:07 AM
Only.code is p0302. Plugs looked ok i changed them and all coils along with injectors and I still have the code I cleared it and it comes back every 100 miles or so.
Oldblue Feb 12, 2025 07:00 AM
Oil in #2 spark plug hole? A leaking valve cover gasket
Bigge313 Feb 16, 2025 08:51 AM
Ok so i figured out why #2 looked that way. Turns out the plug was not seated all the way down. There was a load of carbon build up preventing plug from threading in. After I pulled the head I noticed the spark plug was sticking at least a 1/2 higher that the other 3. I cleaned the threads with a tap and now plug is in correctly. Threads cleaned out perfectly or I would have put in a helicoil but no need. Now I think I might need to replace the piston rings. After I put everything together my compression is 150 125 180 180. Dry. 190 190 210 210. Wet
Bigge313 Feb 16, 2025 08:53 AM
BTW bought car 3 years ago. This is the first I've had plugs out so it was previous to me that the plug did not seat. Been daily drivng (60 miles a day) it for 3 years and no issues until #2 cylinder misfire. Would the rings cause the misfire?
Oldblue Feb 16, 2025 08:59 AM
More likely slightly bent valves , did you inspect them, possibly burnt exhaust valves, maybe it’s just me but when I have the head off for a new head gasket I always go proactive and install new valves and gently hand lap them, why do the job twice. Just my experience.
PulpFriction Feb 16, 2025 09:11 AM
If you think the rings are sticking in that cylinder, you could try dropping in a teaspoon of ATF. Let sit for a few minutes. Spin the motor a turn or two. Let it sit for a couple days. Then give it a nice workout. Maybe some Seafoam in the oil.
