Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Never seen this before need help figuring out where to look (https://www.chevyhhr.net/forums/maintenance-upkeep-50/never-seen-before-need-help-figuring-out-where-look-67438/)
donbrew Feb 16, 2025 09:12 AM
Or, SeaFoam.
firemangeorge Feb 16, 2025 09:42 AM
Guess I missed it but why did you pull the head ?
Bigge313 Feb 20, 2025 06:40 AM
Soryy i have bee. A little busy. The timing chains needed replaced i noticed oil had gotten milky so figured good time to change head gasket since I was there. Turn out the oil fill tube was letting water in so I changed gasket for nothing other than it let me see the problem with the plug so over all not that big of a deal. Update i put some marvel mystery oil on both 1 and 2 cylinder. Let it sit for a day then threw the rest of the can in the crankcase. Also put a can of seafoam in the gas tank. So far I've driven 300 miles and no codes have shown. My scanner is still picking up the #2 misfires but the amounts have drastically dropped. I'm going to keep driving it for a little while and see what happens. Thanks for all the help
donbrew Feb 20, 2025 07:56 AM
2 misfires produce a code.
Bigge313 Feb 20, 2025 04:32 PM
Still no codes. Cheap scan tool from amazon so not much faith in it
donbrew Feb 20, 2025 08:55 PM
Does your engine have coil on plug or one coil pack? If it has one coil pack it operates on "lost spark" like a Harley-Davidson; there are 2 misfires every revolution. Otherwise, some misfires are normal.
Bigge313 Feb 21, 2025 05:24 AM
Coil on plugs.
