oil leak
Old 11-19-2018, 11:20 AM
mmont50's Avatar
oil leak
I have developed a small oil leak. My driveway has slope to it, and I always back my panel up the driveway and it drips a few drops each time I park. So I just parked in the garage (a level place) over the weekend with a drip pan under it to see if I could find the leak. It didn't leak a drop. Checked the oil filter, no leak, and the drain plug, no leak there either. I did notice some oil residue around the oil pressure sending unit, is it possible this is my culprit? Any help would be greatly appreciated...I hates oil leaks.
Mike
2008 LT2 Panel
141K miles
mmont50 is offline
Old 11-19-2018, 12:36 PM
A common problem, here is a how to....
https://www.chevyhhr.net/forums/how-...ng-unit-57962/
Oldblue is offline
Technical Moderator
Very good chance.
donbrew is offline
Old 11-19-2018, 12:54 PM
Doc brown's Avatar
Mine has a similar leak. Read this first part of this thread. This is my issue. However it's been leaking maybe a drop a day since about 90k miles. Never got any worse. It currently has 155k. I replaced the oil sending unit and that was not the issue. My leak is on the crank case seam just above the oil sending unit so that it looks like it's coming from the OSU. Strangely enough it does not leak in summer, only during cold weather. Also the leak slowed when I switched to synthetic oil. It doesn't really lose enough oil to have to add any on a regular basis.
Doc brown is offline
Hellraisehr
04-15-2019 03:48 PM
junker
11-18-2009 12:06 PM
alw
01-04-2009 04:22 PM
stranger
2.0L Performance Tech
7
12-01-2008 04:01 PM
pobryne
06-05-2008 09:47 PM
Quick Reply: oil leak
