Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Oil Sludge (https://www.chevyhhr.net/forums/maintenance-upkeep-50/oil-sludge-67669/)
GrumpyMrGrouper Aug 4, 2025 09:35 AM
Oil Sludge
Hi everybody I'm new here. I just picked up a 2010 HHR 2.2.L from a friend of mind, It has been sitting for a couple years after his mother passed away, anyways... he let me have it and flat bedded it over to my house. First thing I did was perform an oil change. The filter was collapsed and gummed up with sludge, damn thing looked like really crappy chocolate cake. I said screw it and replaced the filter and performed and oil change, To my surprise the thing ran alright besides a random misfire. I had codes for the cam solenoids too so I replaced those, it ran a little better. I ran some liquid Moly in the engine and did another oil change and the miss got a little better. Did it again with Seafoam and it ran slightly better still. I drove the car down the road a few miles and back without the check engine light even coming on but the misfire was still there. I knew what I had to do... take apart the engine and clean all the sludge out of it. The sludge is milky and not baked on, I think I lucked out. The car doesn't overheat, I did get a flash of the oil light but no nig deal. It runs pretty damn good for being neglected so I can't see myself swapping the engine out. So far, I removed the valve cover, the intake and the oil pan. Next, I'll be getting that timing cover off, the exhaust manifold and the cylinder head. I'm hoping I can just clean the crap out of all the parts and replaced the timing cover/oil pump and timing components associated with it. Just wanted to share my experience. Do your oil changes and run intake and fuel system cleaner.
https://cimg6.ibsrv.net/gimg/www.che...406ad7b830.jpg
https://cimg7.ibsrv.net/gimg/www.che...2c2f34d412.jpg
https://cimg0.ibsrv.net/gimg/www.che...983ba43d24.jpg
https://cimg1.ibsrv.net/gimg/www.che...129e906cac.jpg
https://cimg2.ibsrv.net/gimg/www.che...2ecbd402c2.jpg
https://cimg7.ibsrv.net/gimg/www.che...7da1d1b519.jpg
https://cimg8.ibsrv.net/gimg/www.che...b369e25f35.jpg
Oldblue Aug 4, 2025 10:07 AM
A classic case of neglect, the most effective way to get the sludge out is the way you are doing it!
donbrew Aug 4, 2025 11:16 AM
What are the codes? What do you mean "missing"?
If the oil looks "milky" do you mean like "chocolate milk"? That would indicate coolant getting into the oil.
I would run some Seafoam in the oil for 1,000, or so miles and do an oil change.
Collapsed oil filter is normal.
Check the chain before replacing it, any slack between the sprockets is bad.
Looks like 15 year oil change interval.
greg8453 Aug 4, 2025 07:55 PM
If you are not very very careful and get some of that sludge into an oil gallery you'll be having big problems.
GrumpyMrGrouper Aug 5, 2025 07:57 PM
It has a P0300 random miss. The sludge must have been too thick to work the cam actuators, oil passage ways etc. I almost got the whole engine out for cleaning and performing a leak down test. There’s no way I’m reusing the timing cover and oil pump so that’s getting replaced. I just can’t believe the car ran and didn’t over heat or blow up. These must be good engines. I cleaned up the oil pan, oil pickup tube and valve cover along with the dipstick tube and valve cover. The oil was not baked on at all so cleaning it was time consuming but rewarding. I just have to wait for some money to come in so I can buy a hoist and engine stand. Too bad there’s an EPA and I care about the environment or id just pressure wash the whole damn thing.
https://cimg5.ibsrv.net/gimg/www.che...fa97d647d.jpeg
What a freaking mess!!!
https://cimg7.ibsrv.net/gimg/www.che...bbe785165.jpeg
Not going to attempt it, new pump and new cover required.
https://cimg3.ibsrv.net/gimg/www.che...9219cb5d4.jpeg
So much better!
https://cimg1.ibsrv.net/gimg/www.che...ed4276000.jpeg
Nothing a little elbow grease couldn’t clean up
https://cimg4.ibsrv.net/gimg/www.che...e7e5bd541.jpeg
Just like new!
Oldblue Aug 5, 2025 08:34 PM
A suggestion, this timing chain kit includes the replacement bolt for the front guide and the stronger front guide
https://zzperformance.com/products/z...ming-chain-kit
And the front cover
https://zzperformance.com/products/f...c-2-0-2-2-2-4l
firemangeorge Aug 6, 2025 06:18 AM
Wondering why this thread is in the “War Stories” section.
Almost missed it buried down here.
GrumpyMrGrouper Aug 6, 2025 07:16 AM
I just didn't know where to put it. This is a personal war story so far, the battle against a neglected engine. I'm hoping to have it all up in running within the month.
GrumpyMrGrouper Aug 6, 2025 07:20 AM
Thanks, I plan on replacing all the timing components... sprockets, guides, tensioners, VVT's, chains, water pump, etc. I'm not going to take any changes and reuse the stuff that was exposed to the abuse this engine has taken. Besides, more parts replacing means less cleaning for me.
Oldblue Aug 6, 2025 08:01 AM
Sounds like you plan on keeping this car for a long time, don’t go cheap on the timing chain, I’ve had one that stretched after only 20,000 miles and the front guide is a weak point for the upper bolt to fail and the lower parts to vibrate loose and break apart….. bend valves and pistons destroyed!
