Oil usage
Old 07-28-2017, 07:19 PM
According to my compression numbers the rings are ok, but ten years old with a 1/4 million miles on them.
Oldblue is offline
Old 07-28-2017, 08:13 PM
What compression results did you get?
RJ_RS_SS_350 is offline
Old 07-28-2017, 08:17 PM
#1- 145
#2- 145
#3- 150
#4- 145
I had a look with a boroscope, the intakes aren't caked like in the turbo engines, but the oil consumption killed my catalytic converter.
The test was last October after I changed the timing and balance shaft chains.
My oil isn't filling up the catch can, I did move the catchcan down and over to the engine lift loop by the upper engine mount.
Oldblue is offline
Old 07-28-2017, 08:37 PM
#1- 145
#2- 145
#3- 150
#4- 145
Those are pretty darn good numbers. I know you had some oil in that tube, but maybe your cat was murdered by oil getting past the guides(or combination)?
OP may have much different compression results.
Old 07-29-2017, 12:29 PM
True, I believe I'm gonna be doing valve guide seals, this winter, that might ease the oil , but it's not getting past the catch can intake hose.
Oldblue is offline
Redshift
12-10-2010 09:48 PM
HotrodHomeRecker
12-14-2009 11:36 PM
esmarkey
02-10-2009 09:34 PM
Hotrodbob
10-02-2007 11:20 PM
EL_REY
2.4L Performance Tech
14
08-28-2006 06:53 AM
Quick Reply: Oil usage
