Oil usage
Old Jul 27, 2017 | 02:51 PM
kuglerm212's Avatar
Question Oil usage
Hi guys, I have a 2006 HHR 2.4 with 345,000 miles and since day one of owning the car I've only use full synthetic oil swearing by my last 2 cars this is the way to go rather conventional or semi syn. Now having a car with this many miles it's using oil(not leaking) and around 2500 miles I have to add a quart or two. Is there a product on the market that can slow down the oil consumption that someone has tried and actually worked? I've tried a couple products that was supposed to work but didn't come close to working. Any suggestions? I love my HHR and want to keep it as long as possible
Old Jul 27, 2017 | 04:56 PM
That really isn't terrible consumption. Well within GM's "acceptable" limits, IIRC 1 quart per 1,000 miles. And that's for a low mileage vehicle. Not "acceptable" to us of course.
I suppose you've tried the "high mileage" oil, for vehicles over 75,000 miles. Yeah, you passed that long ago!
345,000 miles, keep doing what you're doing, seems to be working pretty good.
I know, I didn't answer your question.
Old Jul 27, 2017 | 05:06 PM
I have found that Mobil1 seems to burn more than others. You might try other brands.
"High mileage" oils have seal glop in them.
There are no miracles in a bottle.
I wouldn't use any thickeners in a 2.4L it has VVT valves that depend on 5W30 to operate properly.
Old Jul 27, 2017 | 08:25 PM
Check the hose that goes from the valve cover to the rubber elbow at the throttle body, it might be sucking oil there to the TB
Old Jul 28, 2017 | 02:57 PM
kuglerm212's Avatar
Yup still using Valvolene 5W30 full synthetic high mileage and never used Mobil
Old Jul 28, 2017 | 03:00 PM
kuglerm212's Avatar
I can check that tomorrow when this pouring rain lets up, am I looking for anything specific?
Old Jul 28, 2017 | 03:46 PM
Oil in the elbow! That's not good but easily fixed
https://www.chevyhhr.net/forums/2-2l...ormance-58332/
Old Jul 28, 2017 | 03:53 PM
If there were oil in that hose, it would signify worn piston rings, which I'm sure is the case, with high miles like you have. The rings wear, increasing crankcase pressure, which forces oil vapors out through the PCV system, and into the incoming air stream. With badly worn rings, oil also then can get from the crankcase, past the rings, into the combustion chamber and burn off.
The formulation of the high mileage oil or other additives is to soften seals and reduce or prevent oil leaks. If you have no leaks, your problem is most likely rings and/or valve guides. A compression and leak down test may tell which one, or both.
Old Jul 28, 2017 | 03:56 PM
You can keep it out of the intake air stream, but that's just treating the symptom. The crankcase is still going to lose oil if the rings are worn.
Old Jul 28, 2017 | 04:24 PM
kuglerm212's Avatar
Thank You
