Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Old Cabin Air Filter (https://www.chevyhhr.net/forums/maintenance-upkeep-50/old-cabin-air-filter-63486/)
Ronnie Aug 15, 2020 07:55 PM
So I just took out my old cabin air filter. I was a bit surprised with it's condition. I was expecting it to be dirty...but not to be mangled.
:wtf:
https://cimg6.ibsrv.net/gimg/www.che...6a7027d60b.jpg
Lonwane Aug 15, 2020 08:09 PM
That happened to me with an STP cabin air filter.
That also happens when the filter is forced in.
I now use Fram as they have stiffer sides.
Ronnie Aug 15, 2020 08:21 PM
I looked inside the filter housing...and there is hard plastic inside that appears to be what's causing the mangled mess. Unless whoever put the last one in didn't go upwards with the filter.
sleeper Aug 15, 2020 08:40 PM
That's why it's so clean. it wasn't working right.
I had that happen on a cheapie filter also.
Lonwane Aug 15, 2020 08:59 PM
When installing a new filter you can feel that plastic intrusion.
That tells you it is not being installed correctly.
As you said Ronnie the filter has to be installed with care and precision. :snoopy:
Ronnie Aug 15, 2020 09:05 PM
Hopefully I got the new one in without incident. I don't want to remove it to check!
sleeper Aug 15, 2020 09:22 PM
:twothumbs:
Oldblue Aug 16, 2020 07:31 AM
Check it again in 2 or 3 years, lol.
that mangled filter could be the reason your AC drain is clogged up
tiapetra Aug 16, 2020 12:41 PM
:thumb:
Most likely.
You can remove the plastic cowl cover to both check the install of the filter and clean out the leaves.
And you can bet there is a bunch in there.
The cowl cover does not seal very tight.
Ronnie Aug 16, 2020 02:32 PM
Originally Posted by tiapetra (Post 899781)
:thumb:
Most likely.
I did that last weekend when I put in the new butyl patch.
