outsidedoormirrorsremotecontrolswitch
my 2011 lt2. need to replace the outside view mirrors switch. I checked the fuse and found it good. so now I'm going to replace the remote control switch. some one please tell me how. thanks in advance. len
Fairly easy Len, remove the interior door panel on the driver's door, disconnect the wiring harness clipped to the switch remove and replace the power mirror switch install the door panel.
Here is a video for you to view to get move familiar with the procedure |
And here is the switch
http://m.ebay.com/itm/CHEVROLET-MALIBU-HHR-MONTE-CARLO-OEM-MASTER-SWITCH-POWER-MIRROR-SWITCH-15261340-/300812262902?nav=SEARCH |
remotecontrol mirror switch
thank you for the info, I will give it a try. by the way congratulations on your award. len
Thank you, len.
