Question about AC
Question about AC
Hi all, I have a 2008 hhr about 280k miles on it. Never once had a problem with this guy except I had to replace the battery some years ago. About 3 months ago the AC seems to have stopped working. Air will still blow out at full strength but it is not cooled at all its just blowing ambient temperature air at me. I am not much of a car guy but have an engineering background so not afraid to DIY. I am just a little unsure of what could be the cause of the issue, from searching it looks like I made need to replace the refrigerant or could be a full on compressor issue. Was wondering if anyone else has encountered this problem and if there are any quick ways to tell whether I need to look at replacing the compressor or just buying some 134a, thank you!
Use your Mark I optical sensors yo see if the compressor clutch is engaging. Then check the diode #9 and fuse #22 in the under hood fuse box. Then look at the connections on the AC switch.
I don't recommend those freon kits, unless you know what you are doing. The freon does not leak unless the connections have been messed with.
I know it is technically not freon.
