Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Question about coolant in lower hose (https://www.chevyhhr.net/forums/maintenance-upkeep-50/question-about-coolant-lower-hose-67611/)
sleeper Jun 15, 2025 02:40 PM
Just serviced my '08 w 2,4,
I ran it a while after running around, temp 180, parked shut off & grabbed lower hose, it was real warm like upper hose, but was solid full.
I couldnt squeeze it. Does not overheat, runs well. Don't see any leaks or lowering in overflow tank
Just never checked hose after use & shut down. Cold it can be squeezed.
Seem normal to you guys ? Im almost @ 40K miles,
sleeper Jun 15, 2025 03:17 PM
Appreciate any input...
Oldblue Jun 15, 2025 04:20 PM
A coolant drain and fill needs a couple of burps to get the air out. Give it a couple of days to get that air out.
donbrew Jun 15, 2025 09:20 PM
15 psi.
sleeper Jun 16, 2025 08:44 AM
I did have it jacked up in front & tried burping it for 2 days.
Originally Posted by donbrew (Post 956084)
15 psi.
Got new OE pressure cap which is 15 psi
sleeper Jun 16, 2025 08:51 AM
Thinking about replacing T Stat now, Should have done it when I did coolant.
Lonwane Jun 16, 2025 08:55 AM
I agree with Donbrew.
When warm the system is under pressure.
sleeper Jun 16, 2025 10:00 AM
True, ALL thanks for feedback..
donbrew Jun 16, 2025 10:06 AM
Somebody can understand short answers!
sleeper Jun 16, 2025 03:16 PM
Got it now Don. Thank You Sir.
