Replacing fog light bulbs?
2008 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1737648
Front Fog Lamp Replacement
Callout Component Name
Preliminary Procedure
Remove the forward portion of either the LF or RF wheelhouse liner. Refer to Front Wheelhouse Liner Replacement .
Disconnect the fog lamp bulb electrical connector.
1 Front Fog Lamp Assembly
Procedure
Remove the adjuster screw from the outer locking ring fog lamp assembly.
Release the four front bumper fascia tabs securing the outer ring to the front bumper fascia and slide the locking ring from the lamp horizontal pedestals.
Disengage the lamp assembly from the locking tabs on the front bumper fascia.
Pull the fog lamp housing, rearward from the front bumper fascia.
2 Front Fog Lamp Bulb Assembly
Caution: Refer to Halogen Bulb Caution in the Preface section.
Procedure
Turn the bulb socket a quarter turn counterclockwise in order to remove.
Procedure
Procedure
Got something on the whole fog light assembly? My drivers one popped backwards into the front bumper area after a hairy crossing of a mountain pass.
Looks like it should just kinda snap back in, doesn’t look like any damage....
That much I do not know. But, in any case, in order to access the forward lights, you must remove the well liner..
Btw, it helps to turn the vehicle tire opposite the side you are working on. So if it's left, turn it right, and vice versa.
I hear ya.. if it's wet, taKe a towel to kneel on, and pop the little rivets, VERY CAREFULLY. P.I.T.A. to get them off. Recommend you use a pair of needle nose pliers. Pull back the liner, and see what needs to be done..
Also, if you are under warranty, you should be able to get the rivets replaced at no cost under warranty, if not, it's probably like $6 for the 3 rivets brand new..
Here's a video on youtube http://www.youtube.com/watch?v=A8NuRiyY5XI that shows replacement of a bulb, then the entire assembly. Should give you the info you need to pop yours back in place. (Disclaimer: not affiliated in any way with 1aauto... just saw the video the other day so thought it pertinent to this thread)
Daryl
Daryl
