Replacing the Serpentine Belt
Hey fellow HHR owners
First post here ever...
I have to replace my serpentine belt and noticed last night that there isn't a whole lot of room in there to move around. I thought I might limit my frustration a bit and ask the experts first. Any tips or tricks or secret passageways?? My dealer wanted $130.00 to do the job, thought it was kinda high as I used to do this work on my old little jimmy all the time.
Thanks from Canada
no canadian jokes eh!
Thanks from Canada
Welcome.... Not sure where the experts are at the moment, but here goes..
Perhaps the illustration will help, Yes it is tight conditions.
I would start at the crank pulley & then go over the A/C pulley, pull back the tensioner, & loop it over Alternator & gently release the belt tensioner..
IIRC a 3/8" drive rachet will fit the tensioner square hole (see pic) to pull up on it.
easiest way of doing it is with 2 people....one pushes up on tensioner while other slides belt off the alternator....and then to put it back on...go from the bottom up....crank, a/c, tensioner...then push up on tensioner and have second person loop onto the alternator...no more than 2 minutes to remove and reinstall
mrsilent13 is spot on with his suggestions. Did mine exactly that way @ 75K miles and it literally was no more than 2 minutes.
Wheel was off for another reason so that made it easier but we didn't remove any panels.
