Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Stock Rotors (https://www.chevyhhr.net/forums/maintenance-upkeep-50/stock-rotors-10835/)
Markiemark Sep 27, 2007 10:08 PM
Stock Rotors
Does anyone know, if the stock rotors are also used on other Chevy vehicles??
I would assume that they are not anything specially made for HHR's?
The reason I ask, a large Auto Supplier, still does not have a part number or rotors in their system, although they have drums, brake pads, no rotors!?!?!?
They said, there is a part number for a NEW part from a supplier, but not available for 4-6 weeks.
I need to purchase rotors, and would like to go with just regular replacement rotors, seeing as you can purchase 3 pairs, in comparison to one pair of the Drilled/Slotted Shiney ones?!?!
Anyone buy regular replacement rotors?
Thanks!
Old Ray Sep 27, 2007 10:23 PM
I guess that they should be the same as the Cobalt but one of great knowledgeable wise ones on the site will know. :smile:
You might be able to cross reference them backwards with the shiny ones if the Cobalt and the HHr take the same part #.
hvrod Sep 28, 2007 08:02 AM
Yes.. cobalt is your choice..
Look at Chevy.com
and look at the specs of the Cobalt
HHR is 11.65 x 1.02 (front)
Cobalt SS coupe sedan/ SS coupe - 296mm x 26mm
(11.65 x 1.02) conversion for you
May I recommend > http://www.crateenginedepot.com/stor...arts-C192.aspx
You will see these beauties on my SS Panel Build... 4 disc setup.. (you heard it here first....) :one: And their GM Parts
