Sunroof adjustments
Hi is there any way to andust the sunroof to pull down tighter into the roof line? Tried cleaning the track and silicone on the rubber and roof contact points. It bettet but still need to push down on the front to seal. Thanks
A quick search resulted in these articles from the archives, have a read
https://www.google.ca/search?q=hhr+s...iw=375&bih=626 |
You might try this from the how-to library (where you originally posted this query).https://www.chevyhhr.net/forums/how-...overage-11629/
My HHR to shop for 2nd heater motor resistor. Shop not buying GM parts from dealer, and I've had several returns like 2 fuel pumps for my Mazda pu. I had a broken 2006 driver's side Sunroof closing arm for close to 2 years. My bodyman took a GM part F Bracket #20794829 $5.53 on line from GMPartsnow, drilled out the 06 bracket, filings into headliner? who cares at 16 yr old car..had to manupulate the screwed in bracket to get the slide to work but he's strong and has tools to slightly improve parts, Worked 4 times, closed never to reopen again! Never own a sunroof car. Trouble about to happen.
