thermostat ??
Old Dec 12, 2015 | 09:14 AM
figuinhos's Avatar
Question thermostat ??
Hi.
my hhr this with a little problem.
the pointer temperature is always falling from the 90cº for 0cº .
and causes the fan is always working .
will be the thermostat ??
Old Dec 12, 2015 | 09:50 AM
Yes it will be the thermostat, if you can get a GM AC Delco thermostat and use Dexcool 50/50 mix.
Old Dec 12, 2015 | 10:36 AM
figuinhos's Avatar
Thank you for your help
Old Dec 12, 2015 | 10:59 AM
db/sb's Avatar
Here you go, I made it 'clickable':
https://www.chevyhhr.net/forums/how-...l-p0128-24493/
Old Dec 12, 2015 | 11:19 AM
figuinhos's Avatar
yes it helps.
I have done the order , then so is mounting . thanks again
Old Dec 12, 2015 | 08:46 PM
ImNewHere's Avatar
Mine took 10 minutes to change. I can't believe I let it go 3 years.
Old Dec 21, 2015 | 12:30 PM
figuinhos's Avatar
Hi.
after better check the car . I found that what was causing the problem was the VALVE temperature. VALVE that is close to the thermostat. It is a piece of brass.
Hugs
Old Dec 21, 2015 | 01:25 PM
The temperature sensor, by the thermostat?
Old Dec 22, 2015 | 04:36 AM
figuinhos's Avatar
the part that I am referring to is this .
this sensor is located on the back of the engine. near the thermostat
Old Dec 22, 2015 | 04:40 AM
figuinhos's Avatar
It was on this site where I got the part.
AutoParts Logistic | Loja Online de Peças Auto,,
