Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   We are now handling Clearkote detailing products!! (https://www.chevyhhr.net/forums/maintenance-upkeep-50/we-now-handling-clearkote-detailing-products-11079/)
GDZHHR Oct 11, 2007 10:27 PM
We are proud to announce that The HHR Store is now an official CLEARKOTE dealer.
If you have not seen how this stuff works, it's INCREDIBLE!!
https://www.chevyhhr.net/gallery/fil...ikshinebig.jpg
Quik Shine ($14.95 + S&H)
  • An excellent color enhancer and maintainer developed for use on all paint, metal, gel coat, fiberglass, plastic surfaces, glass, tinted windows, Lexan and Plexiglas.
  • Used to maintain luster after polishing with Moose Wax or Vanilla Moose Wax Hand Glaze.
  • After washing and drying vehicle, lightly spray on Quik Shine. Using a soft towel buff to a brilliant luster. Every time Quik Shine is used the surface gets polished.
  • Developed for the aviation industry to be used on Lexan and Plexiglas windows.
  • Outside auto: Use on everything except tires.
  • Inside auto: Use on everything except fabric surfaces.
  • World's best furniture polish. Cleans windows, mirrors, microwaves, plastic counter tops and linoleum floors.
  • Will not leave fingerprints. Anti-static properties repels dust.
  • Rain sheets off windshield without tracer marks or streaks from wiper blades, when they need to be used.
  • Contains no Teflons, silicones, alcohol or abrasives.
  • Makes metallics and pearls explode out of the paint at you. Enhances the color of all paints, reds are redder, blacks are blacker, etc..
https://www.chevyhhr.net/gallery/fil...moose_sbig.gif
Vanilla Moose Wax-Hand Glaze ($14.95 + S&H)
  • To remove those 'Spider Web Scratches' that are induced during washing or drying.
  • It can be used with a buffer for outstanding results.
  • Use on all paint, plastic, glass, chrome and rubber molding around windows.
  • An excellent oxidization remover.
  • Use before Moose Wax and maintain that wet deep rich color and luster with Quik Shine between waxing.
  • This item only available in Pints.
GDZHHR Oct 11, 2007 10:28 PM
https://www.chevyhhr.net/gallery/fil...ubbervinyl.jpg
Rubber/Vinyl Treatment($10.95 + S&H)
  • Use on all rubber, and vinyl to add richness and increase luster.
  • Use on rubber seals to keep them soft and pliable.
  • Use on rubber tires: For the ""natural look,"" apply to tire and let stand for 3-5 minutes then lightly buff off. If you want ""glossy"" apply to tire and walk away.
  • Makes chrome brighter.
  • Whitens all white wall tires better than any product in the industry.
  • Contains silicones.
  • Comes with foam applicator pad
https://www.chevyhhr.net/gallery/fil...oosewaxbig.gif
Moose Wax ($17.95 + S&H)
  • An excellent cleaner/wax used to remove oxidation from all paint, plastic and fiberglass surfaces.
  • Removes grime and road film.
  • Easy to apply and easy to remove. Goes on wet, comes off wet. Will not leave a white residue between seams or around emblems.
  • Can be applied in direct sunlight.
  • Cleans vinyl upholstery.
  • Brings fiberglass gel coat back to original luster.
  • Restores air dams and plastic pieces to original luster.
  • Prevents love bugs from penetrating through paint and into primer.
  • Used to remove scratches and finish out new paint jobs.
  • Contains no silicones, Teflon, alcohol or abrasives.
  • Recommended Use: Every 90 days.
GDZHHR Oct 11, 2007 10:29 PM
https://www.chevyhhr.net/gallery/fil...bottle_big.jpg
Metal Polish ($9.95 + S&H)
  • Excellent on aluminum, chrome or stainless steel wheels.
  • Apply to a rag and buff as usual. Let dry. Buff off residue.
  • When polishing aluminum wheels, the black aluminum oxide ends up on the rag, not on your hands or wheel.
  • By hand, use as a scratch remover on paint and plastic. (headlight lenses, trim... etc.)
GDZHHR Dec 10, 2007 01:53 PM
1 Attachment(s)
Attachment 38813
GDZHHR Jan 16, 2008 08:42 PM
Bump for all the new folks!
GDZHHR Mar 20, 2008 01:49 PM
Springtime bump!
xzombiex66 Jul 13, 2008 09:04 PM
bump!! I won a kit of all this stuff at the 2nd Annual Cedar Point meet, Thanks mike. So has anyone used this? i would like to know how it does.
GDZHHR Jul 13, 2008 09:09 PM
It's pretty incredible. They are going to be one of the vendors at the HHRitage Nationals. You will be VERY pleased.
