Window not working
UPDATED Thread #32 THANK YOU Everyone
They found a Broken wire under the seat 2011 HHR 2.4 2LT My sons HHR Came to visit w/his dog and she hit switch, rear passenger side and opened window, Now will not close He did have a issue sometime closing the rear drivers side off the Master! Picked up a Dorman master switch and none of the windows work! Bad New Switch ? The widow lock light does come on ,so assume have power ! Checked fuse 29 30A and I get continuity Is there another fuse somewhere else ? Used a Fuse box diagram off the net.. Fuse box on passenger side Thanks |
You should trust your owner manual more than some image from the internet.
Fuse #17 interior Fuse #36 underhood |
Pssst , RJ , we’re on the internet! But your right about the fuses.
Rich did you try cleaning the OEM switches? https://www.chevyhhr.net/forums/how-...ontacts-62119/ |
Originally Posted by Oldblue
(Post 921964)
I know, eh?
(Post 921964)
(Post 921963)
Fuse #17 interior Fuse #36 underhood Is there only 1 power source to the master switch or 2 ? I ask because when you hit the window lock button the light comes on . ! My son will check the fuse's tomorrow, Temps will be warmer 35* instead of 15* :) |
Two fuses , two power sources, seems logical. However the power windows fuses are
#17 window RAP #29 power windows those are in the interior fuse panelhttps://fuse-box.info/chevrolet/chev...uses-and-relay #36 under the hood is a power windows fuse but only for the SS turbo’s |
Strange. It came from the 2011 OM...
THANKS again will see what tomorrow brings !
My son will try the old switch today, It did have 3 windows working , And if they work the new switch is NG. Either way he will go to the Parts store and grab some fuses for his kit ! |
| All times are GMT -5. The time now is 04:20 AM. |
