Chevy HHR Network
-   Maintenance and Upkeep (https://www.chevyhhr.net/forums/maintenance-upkeep-50/)
-   -   Window not working (https://www.chevyhhr.net/forums/maintenance-upkeep-50/window-not-working-65122/)
PulpFriction Feb 27, 2022 09:04 AM
Just to clarify, neither the driver door switch nor the rear passenger door switch would close the window? So the window is still stuck open? And ALL the other window switches worked normally?
donbrew Feb 27, 2022 09:16 AM
I feel a :duh: moment coming.
Radco Feb 27, 2022 10:23 AM
Yes that is or was correct :o
With the new master switch in none work now :O !
He just called me and Fuse 17 looks good , I think that is a 2 amp which seems small
And fuse 29 look good . He is headed to Auto Zone to grab some fuse's . Always should have a spare fuse
Is there a window Motor relay ???
He just called me back again and did the swap out back to the old master switch, No windows work !
The buttons do light up at night and so does the rear widow lock button, So some power is there !
So maybe a bad ground ?
Or a hidden fuse somewhere lol,
The journey continues !
Again Thank You all for your info and anywise cracks you may be thinking of lol
He will change all fuse's just for the heck of it when he gets back. now warmer out 29*
Is there a Window Motor Relay ?
Radco Feb 27, 2022 10:25 AM
Only moment coming is a Oh Crap moment lol
RJ_RS_SS_350 Feb 27, 2022 10:35 AM
Originally Posted by Oldblue (Post 921977)
Two fuses , two power sources, seems logical. However the power windows fuses are
#17 window RAP
#29 power windows
those are in the interior fuse panelhttps://fuse-box.info/chevrolet/chev...uses-and-relay
#36 under the hood is a power windows fuse but only for the SS turbo’s
I don't trust the information in that link. The online owner manuals disagree in 2009 thru 2011. I think that layout is only good thru 2008. In 2009, things changed.
Radco Feb 27, 2022 11:07 AM
My son will be changing all 3 just in case lol
He picked up all three fuse's and changed them. He can hear clicking ! At the Master switch or door switch's !
So he will call the shop tomorrow for them to check out !
I see no mention of a relay in for the windows so I assume no relay ? Or Circuit breaker
I am tapping out lol.
Thank You for all the guidance .
This old fart has learned alot :)
Now when I go to install my speakers I am more comfortable unplugging the switch's and popping panels
I will Update what the shop finds. or at least have them close that window till fixed
donbrew Feb 27, 2022 11:38 AM
Does this help?
https://www.chevyhhr.net/forums/atta...wn-windsw1.png
Radco Feb 27, 2022 12:44 PM
Originally Posted by donbrew (Post 922011)
Yes Thanks.He had the right fuse;s !
He changed #17 2amp,29 30 amp and 36 30 amp still NG,,
But he does here a clicking When he hits the window switch, Switch's glow like they should when running and rear window lock lights up !
Pn some cars I heard you can jump the switch harness to close or open a window, have you know anything about that ?
He is going to ask make a appointment tomorrow maybe they can close that window for now if they can not fix it that day !
Radco Feb 27, 2022 02:00 PM
At first that was the issue ! He was having trouble sometimes closing the drivers side before the passenger side had the problem
This time yesterday The dog hit the open window switch and now will not close !
We changed the master switch since that was the issue with the passenger side. Now none of the windows work even when we reinstalled the old switch to test !
He live about 1 hr away from me, But if the weather gets in the 30s next week I will grab my meter if his garage does not have time to check it
PulpFriction Feb 27, 2022 02:24 PM
I wonder if either the motor fried when it hit bottom or the mechanism jammed. I would want to hotwire the the motor and see what happens.
I would also consider putting the original switch assemble back and at least see if you can get back to where you were. It seems maybe the new switch is bad or some wire or connector got damaged in the installation.
