best choice of engine swap for 2006 HHR
Lost oil froze 2006 2.4. Any advice on a replacement?
Find a good used one. You could see if Jasper has a reman available.
2006 2.4 is an odd 1 year only engine with the ignition pack on the valve cover , VVT and an external oil cooler, hard to find but they are out there.
https://www.ebay.ca/itm/165742590405...mis&media=COPY There’s one^^^ |
Are you sure about the ignition pack? I thought the 2.4 always had 4 coils. My book says coil on plug, The 2.2 in 2006 and 2007 was wasted spark. No personal experience.
Originally Posted by Oldblue
(Post 933333)
The OP is 85 and just needs to replace his engine.
And Donbrew is right the 2006 LE5 2.4 l engine isn’t specifically just in the 2006 model year! for fitment any year LE5 will do. https://www.karlkustoms.com/product/...-engine-reman/ https://www.jasperengines.com/blog/j...tec-ohc-engine https://paceperformance.com/i-513499...er-engine.html |
LE5 = Good engine.. I am slightly biased tho..
look at the pictures it's coil-on plugs!
Yes, it is.
The oil cooler is the big difference, they decided it wasn't needed on later models. So, a later model without it will work. 2006-2008 are LE5, the flex fuel 2009-2011 are LE9 not compatible with the ECM.
| All times are GMT -5. The time now is 06:26 AM. |
