Powder Coated Valve Cover
So i cam across powder coated valve covers for the hhr ss. i have the stock air box (which i intend to keep on) i was wondering if any of you out there have a powder coated valve cover with the stock air box on? since the air box covers much of the valve cover i want to see pic to see if its even worth the $$$
Just look under your hood and see how much of yours is exposed. Then you can decide if it's worth it or not. You aren't going to get a better example than that, because someone's picture isn't going to show you from all the different angles
