Bowties
I removed my Bowties to sand and paint. What are you guys using to stick them back on once they are ready. Thanks..
Hi,
I believe that I read on another post that the guys are using 3M double sided tape for automotive use. How did you remove the bowties? I painted my front one by taking the grill assembly off. I haven't done the rear one yet because that was too involved to remove the bar that it is mounted to. Was it difficult to remove the bowtie? Thanks! |
Heard some folks are using the "fishing line as a saw technique" to cut through the factory double side tape. Braided fishing line would probably work best.
I just ran one of those thin utility knives all the way out and cut the bowties right off by passing the blade behind them.
bowie removal
Hey,
I use a reward card from one of the local supermarkets. Worked great. Thanks for the respone on the tape. |
Well, at least one of the three respondents answered what you actually asked.......:lol:
While I painted my bow ties without removing them, I have used an exterior automotive adhesive from NAPA for some exterior plastics on my Trailblazer. It worked great. It comes in a caulking type tube for somewhere around $10. The parts I used it on were glued about 3 years ago and are still holding up well. Look or ask for non-structural automotive adhesive.
Originally Posted by db/sb
(Post 655477)
Bowties
Its cool. The knowledge gained here is always worth reading each post. The responses make not be a direct answer to your question but I find that at some point and time I will be able to use them for something else.
Duncan |
I see that a lot of you guys are removing, sanding and painting the bowties, but I was thinking of removing the rear bowtie and leaving it off. My HHR is an all white lt and I was going to remove and paint the bowtie white to match, but I think leaving it off would look just as clean. Any thoughts?
| All times are GMT -5. The time now is 03:29 AM. |
