bumpstop question
Ok, jus wasnt sure if it needed cut a special way, cuz I thought I seen someone cut it incorrectly and in order to get a new bumpstop you have to buy the whole spring setup and i was wanting to dodge that in anyway I could. Also one other question, does anyone have problems with tire ware or is it a pretty clean drop as far as the camber goes.
Thanks
Thanks
