couple questions
Old Jul 24, 2011 | 04:01 PM
saturnsw2's Avatar
couple questions
hi all
2007 with the chromelooking(but not)17" rims
the 17" rims on the used hhr i bought have a yellowish tinge to them on the front rims.
can this easily be removed?
its almost like yellow varnish and does not seem to want to scratch(with finger nail)
is this clear coat deterioration or can it be removed?
next
my wife's stepdad has a set of upgraded 16" saturn vue alloys(2008 i think)
will these fit my hhr?they have 235/60/16 tires on them with less than 3000 kms.
would these larger tires fit(i know it would throw the
speedo out a bit)mostly worried about clearance in the wheel wells as they are about an inch taller than the 17" that are on now..
thanks,jeff
Old Jul 24, 2011 | 04:11 PM
The answer to the first question is that you are seeing deterioration of the clear coat on the wheels. In the past the former owner let brake dust sit on the wheels for an extended period of time and it stained the clear coat. Not much to be done except for refinishing the rims.
The answer to your second questions is two no's. The bolt pattern of the Saturn Vue is 5 x 115mm while the bolt pattern on the HHR is 5 x 110mm, so the rims won't work. Also the tires are too tall to fit the HHR with a height of 27.1", anything over 26" in height will hit the lower spring perch with the inner sidewall of the tire resulting in tire damage.
Old Jul 24, 2011 | 04:22 PM
saturnsw2's Avatar
dammed it
could have got rid of 2 problems with one step.
i see that some vues had 5 x 110 rims.
how can i tell?
i could always get smaller tires on the height issue,but if the bolt pattern is wrong then thats that.
thanks
Old Jul 24, 2011 | 04:28 PM
Here's a link to the database of Saturn bolt patterns, the Vue is listed as the same 5 X 115mm pattern from '02 to the end of production.
http://www.discountedwheelwarehouse...._Reference.cfm
Old Jul 24, 2011 | 06:52 PM
JavaMann's Avatar
When I was looking for wheels a while back I put together this list of wheels that (to my understanding) are all 5x110. I make no warranty to it, and also it's always important to check the offset too.
CATERA (1997-2001)
COBALT SS SPORT (2005 & NEWER 5 LUG MODELS)
HHR LS LT (2006 & NEWER)
MALIBU LS LTZ SS LT HYBRID (2004 & NEWER)
MALIBU / MAXX (2004 & NEWER)
PONTAIC G5 (GT 2007 & NEWER)
PONTIAC G6 GXP GTP GT (2005 & NEWER)
PONTAIC SOLSTICE (2006 & NEWER)
SAAB 9 3 (1999 & NEWER)
SAAB 9 4 (1993 & 1998)
SAAB 9 5 (1999 & NEWER)
SATURN ION REDLINE (2005 & NEWER)
SATURN L-SERIES (2000 & 2005)
SATURN SKY & REDLINE (2007 & NEWER)
SATURN ASTRA XE XR (2008 & NEWER)
SATURN AURA (2007 & NEWER)
Old Jul 25, 2011 | 09:17 AM
saturnsw2's Avatar
i see you can get adapters to go from 5x110 bp to 5x115 bp,any opinions on these?
would these not push the rims outward the width(1") of the adapter to the fender lip?
also any idea of the cost of resurfacing the stock rims?
thanks,jeff
Old Aug 4, 2011 | 07:03 PM
saturnsw2's Avatar
hi
anyone want to comment on the use of those adapters?
4 x 110 to 5 x 115 so the saturn vue rims will work.
thanks
Old Aug 5, 2011 | 01:01 AM
Adapters can open up a can of worms when used, they will shove the wheels outward about 20-25mm which will give you too much offset with the Saturn rims. Running too much offset will give you long term problems with the wheel bearings and other suspension components, along with degrading the handling of the vehicle.
I know you've zeroed in on the Saturn rims that you have available from your wife's stepfather, but anything you might save by using them would be a false economy. One other thing to consider is the requirement for frequent wheel and adapter torque checks, you have to check the torque on wheel adapters and rims frequently unless you want to rick losing a wheel.
I'd check with a local body shop to see how much they would charge to refinish your current wheels, or look into aftermarket alloy rims in the proper bolt pattern and offset. HHR's are saddled with an odd bolt pattern, but there are enough options available that I'd consider wheel adapters only as a last resort.
Old Aug 5, 2011 | 07:02 AM
jay loukakis's Avatar
Adapters, I buy my tireas from Discount Tire, they told me they wont touch the wheels that have the adapters, as I was considering buying them to give a little wider stance..
Old Aug 5, 2011 | 07:14 AM
saturnsw2's Avatar
hi all
you have convinced me to give up on the wheel adapters.
possibly i will purchase the saturn rims anyway and see if i can trade them for something that will work on the hhr.
thanks,jeff
Wifes07LT
Apr 1, 2013 01:58 AM
whitelightnin
Feb 25, 2013 11:28 AM
08SSREDHHR
2.0L Performance Tech
Jul 5, 2012 06:22 AM
doughboy
Jan 14, 2008 09:34 PM
rebel8ball
10
Jul 1, 2007 01:49 AM
