Custom LED tail lights - NOT IPCW
Old Mar 2, 2011 | 07:23 PM
dudeasif's Avatar
Here you go, enjoy !
This ended up being alot more work than I thought, mostly because the bottom lights are not the same size as the tops. I was warned by someone so I knew a little bit of modifying would have to be done, it was worth it though!
http://www.youtube.com/watch?v=RhiBlOFGHFI
Old Mar 2, 2011 | 07:25 PM
So, no backup lights?
They are bright!
Old Mar 2, 2011 | 07:27 PM
dudeasif's Avatar
Nope, no back up lights. Not like I used them, anyone behind me just better watch out LOL.....They better hear me anyways, with 4 12"s in the back LOL
Old Mar 2, 2011 | 07:28 PM
nacademus's Avatar
You have to cut the sheet-metal?
Old Mar 2, 2011 | 07:41 PM
dudeasif's Avatar
Yes had to cut the sheet metal , the hole where the back up light is was about 1/2" smaller than I needed it to be. Nothing the Dremel didnt handle in a few minutes......
Old Mar 2, 2011 | 09:05 PM
SmootHHR's Avatar
You ain't lyin! Those are crazy bright. Looks perfect tho.
Old Mar 2, 2011 | 09:33 PM
nacademus's Avatar
Could you go back to standard reverse lamps if you wanted? Or is the support now dremeled off?
Old Mar 2, 2011 | 09:34 PM
nacademus's Avatar
What is the source for the LED bulbs?
Old Mar 2, 2011 | 11:27 PM
dudeasif's Avatar
Yes I could put them back to stock if needed. The LED's are actually from WalMart, they are meant to be used on a tractor/trailer. They are like 15 bucks and change a piece. I cut off the back of the stock tail light and epoxied the truck LED's to the back of the tail light bezel.
Old Mar 3, 2011 | 03:24 PM
Gas Man's Avatar
www.superbrightleds.com
