Exterior door handle removal
Old Jan 26, 2013 | 11:58 AM
patokian's Avatar
I did a search and googled this and it only brings up the one thread on this forum and it never really says how other than they just pulled on it after removing the block.
I removed the block no problem, but the handle has the notch around a lever that looks plastic too and just pulling on it seems like it will break something.
so does it slide forward or back or what am I missing about this? dont want to damage old one or anything in the door doing this.
any help would be appreciated
Old Jan 26, 2013 | 12:31 PM
Maybe someone will chime in with details
Old Jan 26, 2013 | 01:55 PM
lafinests213's Avatar
i also want to remove the door handles for painting if any body has a how to please post.
Old Jan 26, 2013 | 06:15 PM
sport's Avatar
handle removal
Door handles... remove the plastic plug on the door edge, look inside using a flashlight and remove the one screw using a Torx driver. Pull the handle out and slide the smaller piece towards the center slightly. Pull the smaller piece out towards you, then slide the bigger piece towards the center, didn't take a lot of force, but kinda popped, then pull it out towards you. Really very easy, I used a small magnet on the end of the Torx to keep from dropping the screw inside the door.
I just did this ...
Old Jan 26, 2013 | 07:21 PM
patokian's Avatar
ok thanks, I will give that a try
Old Feb 2, 2013 | 04:07 PM
patokian's Avatar
oh that ended up being so easy lol, didnt even take 15 min. total. yank it back and lift it out.
thanks for all the helpful info guys.
HHRMom_0791
Oct 15, 2014 09:31 AM
ronconherr
May 11, 2014 03:27 AM
bassbase
Jul 28, 2013 09:34 PM
thena23sosu
Mar 4, 2010 05:30 PM
