Front of sunroof sets glass ~1/2 cm below roof.
Old 06-10-2017, 10:58 PM
Jpak88's Avatar
A couple years ago I had the classic problem with my wind deflector (one plastic arm broke) so I removed the whole thing. Ever since, the front of the sunroof isn't quite flush with the roof. Nothing huge happens as a result... No big leaks water leaks (well, I've had a couple... But for different reasons), no giant gap, the sunroof operates properly.
I'm​​​​​ wondering though if there's anything I can do to raise it up that half cm. I can manually push it up from the inside but it doesn't stay. I assume the wind deflector propped it up to be flush with the car roof.. But I don't want to buy a new one, since they go for $100+
Jpak88 is offline
Old 06-11-2017, 02:24 AM
Have you checked any auto wreckers for a used replacement part?
whopper is offline
Old 06-11-2017, 07:25 AM
aradmahogany's Avatar
Mines been like that for the past four years of ownership. 2006 model year
aradmahogany is offline
Old 06-11-2017, 09:36 AM
Yes the wind deflecter propped up the glass that 1/2 cm. off to the wrecking yard for a replacement ,or to ensure y'all get the right part
Deflector | Genuine GM | 15907353 : GM Parts Direct: Your direct source for Genuine GM Parts
Has this on sale.
Oldblue is online now
Old 06-11-2017, 11:04 AM
Was the deflector a "standard" part when the sunroof was ordered? WHERE DID MINE GO!?!?!!?
Old 06-11-2017, 11:40 AM
Yes it's part of the sunroof, maybe a PO removed it!
Old 06-12-2017, 12:47 AM
Jpak88's Avatar
I've actually seen them on sale there, if I have to ill get one :) but has anyone had any issues going without it? I was thinking about maybe getting one of the exterior ones, or maybe just ignoring it all together.
Jpak88 is offline
Old 06-12-2017, 06:17 AM
The deflector is to direct the airflow over the sunroof opening. It allows the cabin air to be pulled out of the opening.
Without a deflector, the airflow goes into the opening and may even pull loose the headliner.
The stock deflector also cuts down on a lot of the wind noise.
firemangeorge is offline
Old 06-12-2017, 06:07 PM
Jpak88's Avatar
Deflector Genuine GM 15907353 : GM Parts Direct: Your direct source for Genuine GM Parts
Has this on sale.
Question.. How do I remove the old, broken clip and where do I get new ones?
Jpak88 is offline
Old 06-12-2017, 07:56 PM
Have a read thru this thread, look into post #92
https://www.chevyhhr.net/forums/how-...overage-11629/
gmdealerguy
04-14-2011 02:36 AM
Krusty
Mods - Exterior
12
03-15-2011 06:06 PM
chrissgee
10-23-2008 09:57 PM
Quick Reply: Front of sunroof sets glass ~1/2 cm below roof.
