hhr grille paint peeling
Your grill has chrome? Have you sand it before paint? There´s is humidity? I would follow these steps:
- Sand the chrome/finish of the grill with 600 grit sand paper.
- Apply one or two primer coats.
- Apply two or three layers of paint (thin layers).
- Then, finish with the clearcoat.
Don't sand it "all the way down". Its only plastic. Just scuff it really good with a 400 grit scuff block. Primer. Paint. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear.
