hhr grille paint peeling
I painted my grille and the paint is not sticking. Could someone tell me the right steps. Thank you
Your grill has chrome? Have you sand it before paint? There´s is humidity? I would follow these steps:
- Sand the chrome/finish of the grill with 600 grit sand paper. - Apply one or two primer coats. - Apply two or three layers of paint (thin layers). - Then, finish with the clearcoat. |
we didnt sand it down first. Should i go ahead and sand it all the way down or just sand some of the black off? thanks
good prepping is the answer:twothumbs:
I painted my chrome without sanding but used a high quality etching primer first. Sticking great.
Rust-oleum has a great self etching primer.. I used it for my bowties and its holding tight!
Dupicolor adhesion promotor,works great
(Post 573122)
thanks for all the great tips
Originally Posted by doty21
(Post 573082)
Don't sand it "all the way down". Its only plastic. Just scuff it really good with a 400 grit scuff block. Primer. Paint. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. Clear. |
| All times are GMT -5. The time now is 06:49 AM. |
