Hid and drl relay
Old 02-23-2016, 06:47 PM
Xlh883's Avatar
Hid and drl relay
I just got an 07hhr and I'm putting hids in it and I'm wondering if there is a drl relay or fuse I can pull instead of putting in the harness to retain drls (not really a fan). Has anyone does this?
Xlh883 is offline
Old 02-23-2016, 07:09 PM
Technical Moderator
Your profile says you have a 2007. That means your DRLs are the headlights, I'm pretty sure you will have to disable them anyway.
You can check under the fuse box cover for relays and fuses, or look in your Owners Manual. If you don't have one follow the link in my sig for a digital Owners Manual.
donbrew is offline
Old 02-23-2016, 07:17 PM
Xlh883's Avatar
Yeah I haven't looked at it yet, figured someone could reply faster than I could get home lol
Xlh883 is offline
Old 02-23-2016, 08:06 PM
Technical Moderator
Lucky for you I have nothing better to do than read Owners Manuals. LOL.
donbrew is offline
Old 02-23-2016, 09:09 PM
Xlh883's Avatar
Hahaha I look through the manual with this link you provided and it seems there is a fuse and a relay. If I pull either I should be able to run the hids without having to install the relay harness if I'm correct. Should make for an easier install
Xlh883 is offline
Old 02-24-2016, 07:04 AM
Technical Moderator
Try the search box, it's been done before.
donbrew is offline
Old 02-24-2016, 07:08 AM
Xlh883's Avatar
Yeah I spent a couple hours searching here and Google on it but haven't been able to find a concise answer on it. I did it before on another vehicle but it wasn't a Hi/Lo set up
Xlh883 is offline
Old 02-24-2016, 07:29 AM
Technical Moderator
Here's a couple from the "Similar Threads" box at the bottom of this page.
If you're using mobile it's different, but there. I think you just keep scrolling.
https://www.chevyhhr.net/forums/appe...ds-drls-41688/
https://www.chevyhhr.net/forums/appe...-thanks-32396/
donbrew is offline
Old 02-24-2016, 05:57 PM
Xlh883's Avatar
I use mobile so it shows as one thread at a time. I read these before I posted, only thing that makes me wonder is the flickering without the relay but I'm not too worried about it. If it's bad I'll just install the harness
Xlh883 is offline
Old 02-24-2016, 06:06 PM
Technical Moderator
If you keep scrolling you will see that there is a divider "related threads". Everything below that is "similar threads".
What flickering? If you pull the fuse and the relay. or just the fuse.
donbrew is offline
Quick Reply: Hid and drl relay
