I need to lift the car.
Nobody has mentioned that raising the body will do nothing to keep the tires away from the strut.
The ONLY option is to get the correct size tire. Well, I guess you could find struts that are longer with the correct bolt holes.
You just can't change the distance between the axle and the lower spring perch. (that is a period).
You can raise and lower the body a bit, but that is between the spring perch and the strut tower.
this is just the project if it will not work, i will buy new tiers... but for now i want it to look like a big bad road tank, it has to be massive, just like US is... as the old saying goes "if they will not fear You they will lought at You"
