Installing HIDs?
OKay so I got a set of HIDs that came with no instructions lol!!! Im trying to figure it out but im kinda stuck, any advice on how to install? ballast placement, connections? :confused:
Its pretty easy. One thing is if you didn't get a wiring harness to pull the power from the battery you might want to so you don't fry any wires. DO a google search and you will find diagrams of the wiring. I used 3M double sided tape and taped them to the fender liner near the headlight. so they are nice and close.
I this those that just replace the standard halogen bulbs?
HID require less power than the OEM bulbs, you will not burn out the wires.
