LED Bulb Replacement - Load Equalizer Questions
#31
So to further clarify....Does the Cruise Control not disengage when the brakes are used? That would seem to be the issue as that is the only time those lights are used. I will admit that I am just guessing.
Thanx again for ALL of your help.
#32
When the third light illuminates the CC turns off. The CC will not turn on if the third brake light didn't work when you put it into gear. On a standard trans car you need to use the brake sometime before you turn the CC on.
Computers!
Computers!
geodesic
10-16-2007 11:12 AM
