license plate led socket wrong way?
i just installed leds in my license plate housing but one is the wrong way. does anyone know if this can be fixed? it looks like i can take off the hatch handle area and turn it maybe what do you guys think?
http://2.bp.blogspot.com/-G2hKZ44LkY...0/IMG_1171.JPG this one is facing the wrong way... http://1.bp.blogspot.com/-JHct27cGca...0/IMG_1170.JPG also i know this is an interior question but i replaced the dome light with leds but cant figure out how to take off the manual push button ones. http://2.bp.blogspot.com/-RSpLdHhALb...0/IMG_1152.JPG cant figure out these ones... http://4.bp.blogspot.com/-37Er5GqS52...0/IMG_1150.JPG |
Once you put the lens back on it does not matter.
Originally Posted by donbrew
(Post 770281)
Does matter! It gives off like no light when faced the wrong way.
Any ideas on fixing it? And how to get the interior push button lights out? |
To me it just looks like the one light was screwed in the wrong direction. Maybe try twisting it in the opposite way ?
Just basing this on what appears to be some alignment marks on each side of the socket hole. In the 1st photo, the socket doesn't line up like the 2nd photo. The map light bulb. Push the tab down while pulling the bulb's metal loop over it. |
For the map light I already changed it, I'm talking about the push button lights I can't get the plastic covers off???
They pop out the same way as the large lens. Hope this helps.
:duh: turned it the wrong way?
I tried, I don't want to break anything, does anyone have a picture of the push button lights off?
Just a tab on the lens.
| All times are GMT -5. The time now is 07:34 AM. |
