Rear light mod
Rear light mod
So first, yes I did try the search feature. I also looked at each post under the 'Mods-Exterior" that mentions lights or tail lights or rear lights and couldnt find what I was looking for. I saw a post, and I am almost sure it was on this page. Someone modded their rear lights using back up light lenses and red led bulbs in the top tail light holes. I think they referred to it as 'European style'. If someone knows what I am talking about please point me in the right direction. Thank you!!!!
The way HHRs are adapted for European laws is the sub a amber bulb in the back up plug and rewire it to be turn signals, then add a spotlight under the bumper.
The top lens and the bottom lens are not interchangeable.
Somebody tried to use a 2 color LED, but the wiring couldn't be done right.
In any case, it would be great to see the details.
Then like Blues link to so many of them is pick which style you want to go for..
As I too am doing the 4 light conversion I would like others opinion,
Do I
1 - connect both tail light & brake light/turn signal
2 - connect just the tail light
3 - connect just the brake light/turn signal
Do I
