Where can I put a pac LC-1?
I have made a switch panel inside the small storage area next to the shifter.
I drilled 2 holes in the bottom because I can just simply add another flat piece and glue it in to replace the holes and this will only lose 1/16" so I'm not worried.
I was thinking either:
1. remove #2 vent grill and add plastic, then drill 2 holes for each (one for sub, one for tweeters)
2. Integrate both into the next experimental switch panel
3. find somewhere on the waterfall thing for both
4. Make a box inside the cubbie hole in front of the shifter knob
Here is the current switch panel (Will eventually have 4-6 switches, with 2 next to each other, which will make more room)
Here is the pac LC-1,
I have one, just ordered another (finally)
