Dome/cargo light resistor tap
A few weeks ago I ordered Plazma LEDs to replace in my dome/cargo bulbs. They're not supposed to need a resistor to prevent residual glow, but they do. So CarID sent me a 50w, 6 Ohm resistor kit. After finding a video on how this thing actually gets installed, I'm now wondering exactly where to put it. It needs to go on the hot side of the first of the three lights on the circuit (assuming these are wired in series) and to its own ground.
Fuse #27 in the interior block is labeled "interior lights" which tells me that it goes to more than just these three. I'm also not very keen on severing a factory wire to install the resistor. Plus, later I plan to put an add-a-fuse on #27 to power a set of under-dash LED strips. The CarID tech department said it can go behind the fuse block, but I'm almost certain I don't want to put it between fuse #27 and the first thing on that circuit. I suspect that putting this resistor in is going to cause problems later, especially if it's not located in the best place... anyone know where that would be? This is just for the central bulbs in the overhead fixtures, not the 4 individual map lights. |
Originally Posted by Dracos
(Post 717575)
Fuse #27 in the interior block is labeled "interior lights" which tells me that it goes to more than just these three. I'm also not very keen on severing a factory wire to install the resistor. Plus, later I plan to put an add-a-fuse on #27 to power a set of under-dash LED strips. The CarID tech department said it can go behind the fuse block, but I'm almost certain I don't want to put it between fuse #27 and the first thing on that circuit. I suspect that putting this resistor in is going to cause problems later, especially if it's not located in the best place... anyone know where that would be? This is just for the central bulbs in the overhead fixtures, not the 4 individual map lights. I had the same issue, but I ordered these and now I have no issues. And I didn't need to install resistors. |
Originally Posted by TEKNOnaut
(Post 717586)
Just return them and order from VLEDS.com
(Post 717607)
The trick is, the LEDs I got are amber, which isn't a popular color.
Put the resistor AT the light fixture?
Originally Posted by donbrew
(Post 717633)
There has to be a ground of some sort near the radio antenna? If I remember correctly that's where the wiring harness for the lights runs.
The lights are wired up to gradually dim after the door is closed, I wonder if that isn't by way of a resistor/capacitor. Maybe changing values at that point is the key. I just remembered that my memory sucks. The headliner wiring is at the rear, making a good ground available down by the tail lights/battery. |
