Mods - Interior Discussion related to the looks of the interior of the HHR.
Making the rear window sills flat?
Old Dec 25, 2021 | 04:43 PM
hhrumadbruh's Avatar
Any ideas how to make the rear sills flat? Piece of plywood and some rubber? Any ideas appreciated. Don't care about cutting or drilling anything.
Old Apr 1, 2022 | 04:04 PM
Hvymax's Avatar
Section out plastic and make a sill.
You could section out the plastic below the window. An oscillating tool would work nicely. Depending on the thickness of the sill material you could section out a pocket and slide it in. You could also make an entire side panel and work it in
Old Apr 1, 2022 | 04:20 PM
X2 ^^^ small saw as mentioned
Old Apr 17, 2022 | 09:40 PM
Hvymax's Avatar
The oscillating cutting tools are great. Clean cuts almost anywhere with the available variety of blades.
Old Apr 18, 2022 | 09:13 AM
greg8453's Avatar
Man up. Use a saws-all. LOL
Old Apr 19, 2022 | 09:29 AM
Hvymax's Avatar
Every Man should have a sawzall!!! Where did you want that door???
M Baker
Feb 22, 2015 07:30 AM
Haunted_Hot_Rod
Mods - Exterior
7
Dec 22, 2011 07:14 PM
urbexHHR
Apr 24, 2011 03:24 PM
pyro panel
22
Jan 7, 2011 04:34 PM
Ogre999
Sep 25, 2010 03:22 AM
