Chevy HHR Network
-   Mods - Interior (https://www.chevyhhr.net/forums/mods-interior-54/)
-   -   Making the rear window sills flat? (https://www.chevyhhr.net/forums/mods-interior-54/making-rear-window-sills-flat-64963/)
hhrumadbruh Dec 25, 2021 04:43 PM
Any ideas how to make the rear sills flat? Piece of plywood and some rubber? Any ideas appreciated. Don't care about cutting or drilling anything.
Hvymax Apr 1, 2022 04:04 PM
Section out plastic and make a sill.
You could section out the plastic below the window. An oscillating tool would work nicely. Depending on the thickness of the sill material you could section out a pocket and slide it in. You could also make an entire side panel and work it in
Oldblue Apr 1, 2022 04:20 PM
X2 ^^^ small saw as mentioned
Hvymax Apr 17, 2022 09:40 PM
The oscillating cutting tools are great. Clean cuts almost anywhere with the available variety of blades.
greg8453 Apr 18, 2022 09:13 AM
Man up. Use a saws-all. LOL
Hvymax Apr 19, 2022 09:29 AM
Every Man should have a sawzall!!! Where did you want that door???
