Rear Hatch Trim
How do you remove the trim panel that is on the rear hatch ?
1 Attachment(s)
Two clips on the Bottom edge, look sorta like Black Rivets, gently Push the small center piece IN slightly, then Pull the whole "rivet" out.
Now just a matter of PULLING off the rear interior panel. I'll post a pic in a minute or two. :thumb: Happened to have mine off currently took the pic uploaded it to photobucket, resized it, and here you are. See the push clips on the back? Attachment 26850 The cup hand thing for pulling the hatch down also pulls out. |
could not open photos !
Picture works fine - problem is at your end.
Thanks, must be blocked here at work. Will open when I get home !
Careful with that classified information :lol:
Thanks for the info. got the trim panel off last night 1
Originally Posted by TyroneMD
(Post 630009)
